I’m just editing some audio at the moment and really can’t re-record anything. At parts the audio is too loud and goes into the red part of the playback meter. And when it hits the red all the words get a horrible staticy sound to them.
Is there an effect to put on that bit of audio reduce this effect? I’ve tried noise reduction and a few others with them just making it quieter, and not taking away the loud staticy sound at the end.
What are you trying to record (or “re-record”)? …Audio playing on your computer? The microphone built into your laptop? From a USB turntable?
FFmpeg is not related to recording and importing is not recording.
If the audio is [u]clipped[/u] (distorted) you can’t fix that.
But red actually means potential clipping and if it sounds OK with the playback volume turned-down you can permanently turn-down the volume of the file with the Amplify Effect (set to a negative value for attenuation) or the Normalize effect.
Note that if the audio is clipped using the Amplify effect to bring-down the volume will make the red clipping indication go-away but it won’t fix the distortion.
