Import Raw From Excel
Hi,
I have raw data in excel- time in one column, signal amplitude (pressure) in another. The signal is from a pressure transducer, which is essentially an industrial microphone. When I plot the two side by side I get a perfect waveform of the sound made by the equipment I’m “listening” to, which I would like to be able to play back in audacity through a speaker. I know I need to manipulate the file (in excel, Matlab, or some other way) to get it into a format audacity will be able to recognize as a waveform but I am unfamiliar with how audacity reads raw data. Any suggestions?
Thanks!
-TurboMunky
Does this topic help https://forum.audacityteam.org/t/importing-text-as-audio-exporting-audio-as-text/21905/1 ? There is a Nyquist plug-in and a text to binary file converter application there.
