Import plugin in Windows Audacity v 2.3.3
Hello,
How do I import a plugin into my Windows audacity version 2.3.3 ?
Thanks in advance.
grtz,
Gilberto :wink:
See: https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_windows.html
Audacity 2.3.3 is rather old. If you specifically want to use an Audacity 2.x version rather than Audacity 3.x, then I’d suggest that you use Audacity 2.4.2.
If you want to use the most recent version of Audacity, that is currently version 3.0.2, available here: https://www.audacityteam.org/download/
