Import files with .MTS extension
I am trying to import the audio part of video clips. I am successful with the video clips with .MOV extension from my Cannon DSLR, But I can’t import audio from my Cannon Camcorder which has file with .MTS file extension. Any suggestions?
Tks,
Dave
You may be able to convert the .MTS files to a supported format (such as WAV) using VLC http://www.videolan.org/vlc/index.html
Steve, Okay I’ll try that. So in other words, I have to take my .MTS file and convert it to another format and then import it into Audacity?
Dave
Use Media > Convert/Save… in VLC. Save it as “Audio - CD” and add “.wav” (without quotes) to the name of the file. Then import the wav file into Audacity.
Gale, I don’t understand these instructions … use Media ---- where do I find ‘Media’, … and, what is VLC??
Tks, Dave
See my previous post: https://forum.audacityteam.org/t/import-files-with-mts-extension/25388/2
