That should be:
2 (stereo) x 16 (bits per sample) x 44100 (samples per second) = 140800 bits per second = 176400 bytes per second.
1 min 38 = 98 seconds
98 x 176400 / 1024 = (about) 17 MB.
Perhaps the file is a play list file that points to a 16bit PCM file.
Try opening the file in a plain text editor (such as NotePad) and see what happens.
I did opening this in an hex editor. It starts with nice comments . I’m not sure if I’m allowed to post this file to the public. You could find it by extracting the Disk 1 ADF from Pizza Connection 1 for Amiga. It’s in the sounds folder and is called “titel”
Yeah, I did, but the file extends to 1.6MB while converting it. Very odd.
That’s not surprising to me… It depends on what format you converted to. That would be in the ballpark for an MP3, and Steve did the calculations for an uncompressed file (17MB). What format did you convert to?
