Hello
I am new to Audacity and am trying to import a sound file that i have recorded on my Samsung phone the file format is .3ga, When Try to import the file
I have faced a problem about unrecognisable file format. The window mentions i should try importing it using import raw. However this did not work and the file turned out to be white noise. please can you help me
thanks
