Hi,
I’m in the habit of modifying the image cache found in %appadata%->Audacity->Theme->ImageCache.
Is there a way to download and manually reset the image cache? I can’t seem to find an updated version of it online.
Anyone aware of this change?
I appreciate all inputs.
Take care.
EDIT: After further research, I’ve found information on the github. Problem is, a lot of the links there are now down. I also think they are using transparency directly in the image now, which I don’t think was the case previously.
Hi, thanks for that, very cool.
I ran into a problem, I cloned the repository using git bash, but upon trying to open the .py file, it just crashes.
Known problem? It’s probably on my end, I’m not much of a programmer.
Hi.
You probably don’t have all the necessary libraries installed.
Have you tried running install.bat?
If that doesn’t work, open a command prompt and type:
python “AudacityTheme Version Convertor.py”
That should either run the program or list what it doesn’t like.
