IEM plugin suite V1.14.1
hello
i downloaded IEM plugin suite V!.14.1
how to integrate it into Adcty effects
Mac 10.15.7 Adcty 3.2.5
thanks to let me know
As far as I can tell you:
  • run the installer
  • start Audacity
Audacity will scan the plug-ins and enable them (some may not be compatible and will not be enabled). This is what happened on my M1 Macbook running macOS 13.3.1
I don’t know what will happen on macOS 10.15.7.
