I would like to launch Audacity from Python and open multiple wav files simultaneously
Hello,
I’m trying to write a python script which loads Audacity with multiple audio files in the same window. So far I have been able to do this but instead of opening both audio files on the same window, 2 independent Audacity windows are opened , one for each audio file. Is there a way to do this? See my code below
import subprocess
Opening files in A and B files in Audacity
original_mic_file = “A.wav”
cleaned_mic_file = “B.wav”
if os.name == ‘nt’: # Windows
audacity_path = “C:\Program Files\Audacity\audacity.exe”
subprocess.Popen([audacity_path, original_mic_file,cleaned_mic_file])
Use a LOF file
Bingo!!! I was not aware of the existence of LOF files. I solved my problem with the code below
# Opening files in priFile and mic file in Audacity
original_mic_file = "A.wav"
cleaned_mic_file = "B.wav"
if os.name == 'nt':  # Windows
    audacity_path = "C:\\\\Program Files\\\\Audacity\\\\audacity.exe"
    # Creating LOF file for Audacity to open
    script_directory = os.path.dirname(os.path.abspath(\__file_\_))
    lof_file_name = os.path.join(script_directory, "audacity_load_files.lof")
    try:
        with open(lof_file_name, "w") as f:
                f.write("window\\n")
                f.write(f'file "{ original_mic_file}"\\n')
                f.write(f'file "{ cleaned_mic_file }"\\n')
        print(f"Successfully created {lof_file_name} with the names of the audio files.")
    except Exception as e:
        print(f"An error occurred while creating the .lof file: {e}")
    subprocess.Popen(\[audacity_path, lof_file_name\])
