How do I record my voice and then pause it, listen to it, then restart without saving yet? It needs to be saved as mp3 from the get go too. Also I don’t know how to move the dial to e.g. 10 minutes ago. Thanks in advance.
Here is that breakdown in a natural, forum-style format:
Hit Record to start.
Use Pause instead of Stop if you just need a temporary break.
If you want to listen back, hit Stop and then Play.
To keep recording on the same track, just hit Record again—Audacity will append the audio right where you left off.
To move around the timeline, just click where you want to go or type the exact timestamp into the Selection Toolbar (like -10:00).
Keep in mind you choose MP3 under File → Export, not while you’re actually recording.
