Hi,i downloaded audacity but it doesn’t open.It says as follows
audacity.exe - Entry Point Not Found
Big red The procedure entry point _callnewh could not be located in the
X mark dynamic link library
here E:\programess\Audacity\wxbase311u_xml_vc_custom.dll
Please help so i cn apply what i learnt at school at it.thank you
Try updating your computer’s C++ library by installing "Visual C++ Redistributable for Visual Studio 2015 " from here: https://www.microsoft.com/en-ie/download/details.aspx?id=48145 (installation instructions are provided on that page. You should reboot after the installation has completed).
