I’m using version 2.0.5 (which is the version I prefer) and it worked fine until today.
I needed to record some audio and followed instructions from this YouTube video:
The process went smoothly and I saved the recorded audio file to MP3. After I did that, when I went to play and edit the music file, I found that suddenly Audacity won’t work correctly. I am now unable to select anything from the menus and the options are light colored text and un-clickable. I’ve never had this happen before. I tried resetting Audacity but that did not make any difference and it is still behaving this way that will not let me me work on files as I typically do.
I can import and play a file but not edit it ![]()
For example, I highlighted a section of audio after importing an audio file but when I go to the file menu and select “remove audio or labels” I can not choose any selection on the menu. If I go to “effects” or “generate” menu, every single option is light-colored text and un-clickable.
