Just recorded a memorial service and there is a fan noise throughout my 1.5 hour movie – I would like to erase that but don’t have a clue how to do this with Audicity?
Any help
Please see here http://manual.audacityteam.org/o/man/noise_removal.html .
Hi Gale - thanks for that – I Just don’t know if I can seperate audio on the I-Movie? Do I need to import the audio into Audicity then? Or can I import the whole movie file?
Try fixing the noise in iMovie if it’s not too bad ( see http://www.youtube.com/watch?v=2CxLDY2gKbg ) .
If it helps, see http://multimedia.journalism.berkeley.edu/tutorials/imovie/separating/ for how you can exhange audio in iMovie. Install FFmpeg by following these instructions http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#macff . Installing FFmpeg will then let you drag the movie into Audacity and Audacity will load the audio from the movie for you to edit.
Please contact Apple for detailed help using iMovie, but searching the net or iMovie documentation may well give you sufficient clue.
