I keep getting this message, as well as freezing in Audacity 3.7.1
Let me say first, that I love Audacity and have been using it for years. In the version Audacity 3.7.1, I am getting a lot of freezing and messages stating the files did not save properly. When I try to send the error message to support, it is unable to do it. This version is very buggy.
Exception code: 0xc0000005
Operating system: Windows NT
10.0.26100 3194
CPU: amd64
family 25 model 80 stepping 0
16 CPUs
GPU: UNKNOWN
Crash reason: EXCEPTION_ACCESS_VIOLATION_EXEC
Crash address: 0x0
Process uptime: 8829 seconds
I’m not able to help with those issues, but if you know which version of Audacity worked well for you previously, you can probably get it from Old Audacity versions download
FossHub was the official content distribution partner for Audacity for many years until Audacity was acquired by Muse Group, so they have virtually every version going back to 2.0.0.
Be aware that Audacity 2.x uses the old “AUP + _data folder” format, and cannot open Audacity 3.x “AUP3” projects.
I will trying going back to 3.6. I believe that worked ok. Thank you for your response. I use this for editing my podcast and these annoyances are slowing me down.
