I have downloaded version 3.7.7 on Mac. I can't find Normalise. Any clues?
I have downloaded version 3.7.7 on Mac. I can’t find Normalise. Any clues?
I should be under Effect → Volume and Compression → Normalize.
If it’s not showing-up go to Effect → Plugin Manager and make sure it’s enabled.
I’m running 3.7.7 on a Mac and Normalize is in the main Effects menu.
As suggested above, make sure it is enabled
