I have a i9-11900k - What are the best CPU/GPU combinations for Open VINO Super Resolution?
For performance, my guess would be GPU, GPU, GPU – but you’ll probably just need to experiment to see which runs the fastest.
Thanks. Being an Intel product it only supports Intel GPUs so I can’t use the RTX3070 unfortunately. The Intel® UHD Graphics 750 on the i9 is supported and in tests I’ve done so far isn’t as good as CPU. The combination above seems best balance with both CPU and GPU achieving 90-100% load but just wondering if anyone else had done more tests and maybe knows better?
Interested in this too. I have a 11700k and will be doing some experimenting.
