There was a voice effect that i heard constantly in the past that im no longer in. I wanna try to replicate it but ive lost it. ..
basically, music-like noise plays out but its controlled by a voice in vowels and volume.
Not sure if this works but if you know what it is then please do tell me what was it again.
Trebor
February 28, 2026, 11:30pm
2
Vocoder ? , Talkbox ? , (which are not the same … https://youtu.be/-jKB9rT3uxE ).
i tried vocoder, all i got was wah wah, i maybe was doing it wrong…
talkbox is not exactly what i was aiming for but if it gotta do then it will do
Trebor
March 1, 2026, 7:54pm
5
DUOaudiohelpneed:
vowels
There are plug-ins effects which apply vowel filters … https://youtu.be/nBVwN60H4Og?&t=116
HY plug-ins has a free vowel filter … https://hy-plugins.com/hy-mbmfx2-vst2-vst3-au/
would be cool to try that but i cant install plugins for some reason (if you need a idea as to what system im on, im on linux so make of that what you will)
Trebor
March 2, 2026, 10:43pm
7
Apparently it is possible to use VST2 & VST3 plug-ins in Linux , but I’ve never done that myself.
