Hi all,
I am sorry, I need your sage advice again as this one has me baffled.
I am using version 2.05 and have been since it was released. I have not changed Audacity at all. I am using MME, Speakers (VAI High Definition Audio), Stereo mix (VAI High Definition Audio) and 2 (Stereo) Input.
I have the volume set at 100% and input at 100%.
Some time ago, something happened - Perhaps an install? And I had to move the speaker volume up to 90% from 80%. Then last night I installed Video-to-Video and solveig Video Splitter. Then as I tried to close the system down, Microsoft installed an update, saying it was for DVD Playback: http://support2.microsoft.com/kb/3001554
Now today I cannot get the volume up high enough to record properly as I had done. In desperation I got it high enough by setting the volume to 100%, but it was distorted on playback (at all volume settings). Instead I dropped the volume back down to 90% and set the VIA Audio Deck setting for the equalizer to increase EVERY band by 6dB. This gets the recording level back to where it seems best (peaks reaching but not exceeding +/- 0.9) and playback seems fine.
This is on an Asus ROG laptop G75VW running Windows 7 x64 Ultimate. It has 5.1 audio (yes, amazed me on a laptop as well).
Since the only changes I can think of recently are Video-to-Video, solveig Video Splitter and MS KB001554, I have checked their settings. Video–to-Video has volume set to 100%, Solveig does not seem to have a volume setting as such, just “mute” (which is off). I use Daum Pot Player for videos - Also now has volume set to 100%, as is Windows Media Player also.
So everything is pretty much maxed out, but still something last night seems to be reducing the audio by about 6dB now. Has anyone else had problems since the MS update? Does anyone else know what the problem could be? The problem has affected the ACTUAL volume level, until I increased the volume by 6dB on all bands of the equalizer, the computer was noticeably quieter today.
When I open the Volume Mixer, there are three tied volumes - Speakers, System Sounds and Internet, all are set at 90%.
Playback Devices has Disabled and Disconnected devices ticked - Speakers on here seems to often be hitting the top of the green bar at 100%, like the speakers are being driven into maximum, only they are not - Could something be over-driving them because it is getting confused over 5.1 / stereo?
Recording Devices also has show disabled and disconnected devices ticked. The small green level meter displayed on here is showing peak of only about 80% on Stereo mix, and the microphone is disabled
Volume control options - Select which devices show their own volume control - The default device will always show it’s own volume control. All devices currently playing sound is ticked, but the 4 boxes for sound devices (Nvida HDMI Output Port 1, Speakers (VIA High Definition Audio), SPDIF Interface (TXD) and Nvida HDMI Output Port 0) are not ticked.
Please, any ideas what I am overlooking, or doing wrong? - Has something installed it’s own hidden volume control? Is MS KB3001554 doing something odd? Or is something incorrectly interpreting the 5.1 / Stereo issue incorrectly?
Thanks for any advice!
