I have the current version of Audacity-win-2.0.3. It doesn’t say anywhere in Help, if it is zip or exe.
I have Windows 7 Home Premium 64 bit 8GB DDR3 SDRAM, 1600MHz-2X4GB
I am trying to do simple thing but I am not so much technically savvy.
My question for now is why I can’t hear the music while transferring from a simple tape recorder (cassettes) to the computer? I use cable 3.5 mm two male jacks. I put one on the back of the computer and one in the cassette player. If I keep the headset plugged in, it doesn’t work the recording. When I take off the headset, it records but I don’t hear anything. The sound is only in the cable between the devices. I can’t hear the songs. The headset interferes somehow with the cable. I don’t have speakers on the computer, only headset. What can I do to hear what I am transferring?
It could be not important question, if I learn how to delete a song, after I read the manual. I printed the manual and I hope to find there how to delete the unwanted songs and burn the rest to disks, since I don’t hear what I transfer.
Thank you in advance
