When I try to record with my HP laptop’s built-in mic using Audacity 2.3.3, the mic level is low and I get a hum along with some low level noise - kind of like radio static. Windows Voice Recorder usually doesn’t work at all but when I can manage to get it working, it does the same thing.
The noise is not acoustic (not being picked up by the mic). Moving the laptop to a different room, running it on battery versus AC power etc., all has no effect on the noise intensity. The noise does increase/decrease along with microphone level settings.
I’ve had Windows 10 on this machine for a long time - I’m running 64 bit, version 1909 - and the microphone input has always worked fine up until a couple of weeks ago. The PC has no other issues.
What I have attempted so far:
Tried an external analog microphone - no difference.
Ran Windows Recording Audio Troubleshooter; it found nothing.
Used System Restore to go back to a restore point before the noise appeared - no change.
Removed and re-installed the latest Windows driver for the sound card (there isn’t a manufacturer’s version).
Removed and re-installed the latest Windows driver for the internal mic ( " ").
Turned off Audio Enhancements/Sound Effects in Windows.
Ran Windows Update.
Ran Windows sfc /scannow. It found corrupt files & successfully repaired them but there was no change.
Any ideas?
