I time-shifted a track by using the mouse and dragging left/right. I would now like to view the total time shift of the track in seconds. Is this possible?
- Click on the track
- Press “J” (cursor to track start)
- Look in the Selection Toolbar at the bottom of Audacity to see the start time.
This worked, thank you.
Just a note: if the track is time-shifted before 0s, it will show 0 rather than a negative number. To solve this, select all tracks with Ctrl+A and shift them all to start at a positive time.
