Hi,
I am a newbie in sound editing, so I don’t know how to turn a normal speech into a song.
I mean, I want to add rhythm to a normal speech but I don’t know what should I do ![]()
Thanks for your help ![]()
Hi,
Please try using more words. Speech is not music, unless perhaps you are rapping. Is that what what you are trying to do?
I mean, for example such thing : https://www.youtube.com/watch?v=INuHFSPn5bY
Or lots of other famous people’s speeches turned into hilarious songs!
The music is ready & I have cut the words I need already. The problem is I need to give those random words rhythm!!!
I’d guess that was done with [u]Melodyne[/u] or maybe [u]AutoTune[/u]. There is free '“pitch correction” plug-in called G-Snap, but I’m not too sure how well it works or if it will work in this application.
Audacity has a Change Pitch effect, but you’d have to select & change one word/note at a time and it would help if you are a musician or if you have a good ear for music.
