I used to not have this issue, but with an update something changed.
When I used to select a part of a track, then delete it, it would squish the remaining recorded audio together. Now when I delete something, it no longer does that, leaving empty space, meaning I have to click and drag every part of the audio to the left to get rid of the empty space. How can I get things back to how they were?
The current version is 3.6.1. Is that the version you are using? If so, then this may be the problem:
If the track contains splits, then by default, any audio after a split does not move when deleting audio from before the split. To return to the old behaviour, go to “Preferences → Track Behaviors”, and enable the option: “Editing a clip can move other clips”.
This worked, thank you!
