need to reset the default from 16-bit to 8-bit at 22khz
Also note that simply changing the sample depth to 8 bits will not make your audio sound like the old-school “8 bit” sound, in case that’s what you’re trying to achieve. All it will do is add more audible noise to the audio (8 bits has about 48 dB SNR, which gives you quiet but audible noise, while 16 bits has about 96 SNR, which gives you inaudible noise).
If you are after the “8 bit” sound, try out software like GitHub - LemonATsu/pop-to-8bit: A tool for converting pop song into 8bit chiptune song.. I haven’t used it but it looks good.
