How to Select USB
Hi, Can’t find where to select USB
k
I’m a Windows guy, but…
It should be selectable as a Recording Device (or Playback Device).
You can also check your Privacy/Security Settings to make sure Audacity is allowed to use it.
…If it’s a musical keyboard the USB can be MIDI rather than digital audio and in that case it won’t work (directly) with Audacity.
