How to "select all"?
A while ago I accidentally assigned a shortcut to Ctrl+A, meaning I lost the ability to use Ctrl+A to select all.
Is there any way to fix this?
Go to “Preferences > Shortcuts” and set “Ctrl + A” as the shortcut for “All”.
More information here: Shortcuts Preferences - Audacity Manual
Thanks so much! Quite a simple solution. I couldn’t find it because I was looking for “Select all”!
