I was experiencing problems of not being able to record with overdub. The program was pre-installed, and I am suspecting that some other settings might have caused the problem. Removing and re-installing the program did not seem to solve the problem.
Hi. I am a Windows user. Let me suggest starting here: Tutorial - Multi-track Overdubbing - Audacity Manual
Thanks. I am reading and trying it now.
– I do want to reset the settings / preferences. Do you know if there is an option / button / command to do that?
Seems that the Linux repo version is outdated. Can get it to record about once every 3-5 attempts.
Most settings can be reset with “Tools menu > Reset Configuration”.
