How to render the realtime effect in the track
Is there any feature to render the realtime effect in the track?
My workflow: Adjust a song as DJ with e.g. ZamEQ2 - and after that “Loudness-Normalize” to calculate the song to desired loudness level.
At the moment i need to adjust in realtime the eq, save a preset, load the eq after that in the effect section and process the track with the preset, then Loudness-Normalize.
If a feature like “Render in Place in DAWs” (so a new track is rendered with the realtime effects it would nice.
Tracks menu > Mix > Mix and Render.
