How to remove vocals from the beat on Audacity?
Does anyone know how to remove vocals from the beat in Audacity? Please post. I am new at learning the software. Thank you.
You can try Vocal Removal and Isolation.
It’s usually “imperfect”. It relies on vocals being in the center (identical in both channels) of a stereo recording. If you subtract left from right the center is removed, and one of the options does exactly that. If the vocals are exactly centered they can be removed completely. The problems is, there are usually other sounds in the center that also get removed or reduced. (The bass is normally centered but there is a filter so you can keep the bass, and the highest frequencies above the vocal range). There are some more advanced processing options but you rarely get “professional results”.
You can also try Spleeter.
