How to remove vocals from a song?
Hello beautiful people, I’m trying to get into music production and experimenting with different things for learning as well as fun. I want to extract vocals from a song and do something with it. I’m trying to figure out is there any way to remove vocals from a song in audacity? Please help me with this. I need it very badly. Thank you for your help in advance.
Hi. Install and use OpenVino for Audacity, Music Separation module
Are you sure it’s possible at all? I dare to advise you to try…a neural network. For example: MVSEP - Music & Voice Separation
I guess, there’s a lot of them.
Hello, thank you for your reply, I just installed the plugin, but I’m getting the "OpenVino Music Separation Error.” I’m unable to do it.
I think it might be possible. Is it free to use?
Yes, it’s free. But it makes you stand in line. Try https://www.lalal.ai One time I removed music with it for better recognizing lyrics. It worked! You can get both instrumental and vocal separately.
The old Vocal Reduction and Isolation Plug-in is still available.
It’s not AI so it may not work as well but it’s a Nyquist plug-in so it should be “foolproof” and shouldn’t crash.
Thank you guys for you help, I have removed the vocal with the help of garageband as I was getting the "OpenVino Music Separation Error” in Audacity.
Does it work well? Have you tried it personally?
Which one gets the better results?
The best result will always be produced by AI. Your OpenVino version must match a specific Audacity version. Otherwise, you will get this error
I make VP2024’s posts legible:
I’m not good with neural networks, I used only https://www.lalal.ai I can’t say, which one gets better results. I’ve already written, there’s a lot of them. Another one: https://vocalremover.org/ru/
I compared OpenVINO and vocalremover.org. The result is about the same. The difference between them is that vocalremover has a time limit, while OpenVINO works without any limits.
