How to remove a clic by copying left track on right track
I’m working on the cleaning of vinyles and I want to remove a clic on the right track by duplicating a (very little) section of the left track on the right track.
I remember it was easy to do with soundforge but I cannot find such a functionnality in Audacity. Could you help me ?
Thanks a lot
Olllive
Steve made an plugin to do that … https://forum.audacityteam.org/t/copy-left-to-missing-right-channel-solved/40728/3
If it’s just a click, say ~10ms duration, you can just use repair : Temporarily split the stereo-pair into two tracks, use repair on the bit of the track with the click, then rejoin the tracks to make the stereo-pair again.
OK. Thanks a lot. I will try it asap!
