Hy,
I was recording a project when my PC crashed and i can’t save this project.
I restart PC and when i opened Audacity i had a chance to recover, but doing this a message appears "erro not well-formed (invalid token) on line 1374.
I’m using AUDACITY 1.3 Beta (Unicode)
I have Windows XP, please how can i fix this?
If you never saved a project (AUP) then the problem with invalid token is in the “autosave” file. If you still have the 1.3 version open, the autosave file should still be there at:
Documents and SettingsApplication DataAudacityAutoSave .
In cases where the recovery is incorrect, you should always leave Audacity open until the problem is fixed, or if you must quit Audacity, open Windows Task Manager and force quit Audacity only using the dialogue in Task Manager. That way, the autosave file and temporary _data will be kept, and the (incorrect) recovery will be offered again.
If you do not have the autosave file, then see Steve’s link ( http://wiki.audacityteam.org/wiki/Crash_Recovery#Automatic_recovery_tools ) - as described there, you have to do sorting and renaming of the AU files in the Audacity temporary folder, then use the 1.2 recovery utility to make WAV files from the AU files.
