How to start programming in Nyquist to create plugins?
You don’t need Nyquist to create plugins. I designed Audiobook Mastering using the simple Macro process. A Macro is a text file with a list of instructions of what other applications need to do. Also called Chains or Batch.
Macros can’t make decisions. There is no “If This Happens, Then Do That.” A Macro always goes beginning to end and then stop. If you need anything more complicated, that’s when you need Nyquist.
