Hi,
I need to shift to the right on the timeline a whole track, so that I can insert another small track before the beginning. How do I do that?
It’s probably obvious, but I just can’t find it in the documentation.
I’m using 2.1.0 on Windows 7x64.
Thanks for stating the Audacity and Windows version.
Press F5 on your keyboard then you can drag the track with your mouse:
http://manual.audacityteam.org/o/man/time_shifting.html
When you have finished dragging, press F1 to go back to Selection Tool.
Thanks, exactly what I needed.
