Windows 10
Audacity 2.4.2
Attached is image of a portion of track:
I would like to mix the two areas defined by the insertion point. I’m sure there’s a way to do that without bending too much iron, but I can’t figure it out.
Thanks!
Windows 10
Audacity 2.4.2
Thanks!
If you mean that you want to crossfade them, see: https://manual.audacityteam.org/man/crossfade_clips.html
No, I really didn’t want to crossfade - wanted to mix those two areas.
I managed to struggle through and just now got it done:
(BTW: When I did that, the track that contained the split-out part disappeared - what if I didn’t want it to disappear?)
That ended up with what I wanted to accomplish. Is here perhaps a more straightforward way to do that?
I’m not sure exactly what you mean, but perhaps “Mix and Render to New Track” rather than “Mix and Render”.
