plz help me
I need this for may homework(video production)
You could try the Vocoder tool. That combines two sounds in a better way than just mixing. this is one example.
http://www.youtube.com/watch?v=YR_Bjf-a5rs
You put the cat sound on one side and your voice on the other.
alternative to vocoder … https://forum.audacityteam.org/t/how-can-i-amplitude-modulate-one-channel-with-another/8039/1
No method by using Audacity?(like change pitch) ![]()
Try it.
Effect menu > Change Pitch.
change to which %
change to which %
What % did you try?
What happened when you did that?
If you don’t get the result that you want, you can “undo” the effect by selecting “Undo” from the Edit menu.
steve:
enoch1023:
Try it.
Effect menu > Change Pitch.change to which %
Just as a starting point, I tried 40% (about the same as 6 semitones up), and the results were pretty similar to Talking Tom. Now I just have to practice my purring sound…
enoch1023:
steve:
enoch1023:
No method by using Audacity?(like change pitch) :idea:
Try it.
Thx,40%!!
