I’d like to make a Gameboy sound effect in Audacity. My Audacity version is 3.1.3, and I use Windows 10.
While it is “possible” to synthesize Gameboy type sounds in Audacity, it’s complicated and time consuming. You would need to understand how the Gameboy synthesizes sounds (https://gbdev.gg8.se/wiki/articles/Gameboy_sound_hardware) and then emulate that.
I’d guess that what you really want is some software designed to create “Chiptunes” (https://en.wikipedia.org/wiki/Chiptune).
Try googleing for “chiptune software”.
It was always my understanding that nintendo sounded the way it did because of the LACK of sample rate and bit depth used. I don’t know if this is what you’re asking, but I would think you can take any audio project, convert it to a low sample rate with low bit depth (8bit maybe), and it should sound like a nintendo track. I hope that helps.
It won’t. It’ll just sound like a low quality version of whatever it is. For example, if you start with a recording of a piano, it will sound like a low quality recording of a piano.
The distinctive sound of a Gameboy is because of the Gameboy’s synthesizer.
