How to make audio similar to UVB-76 broadcast?
I’d like to make similar audio to an UVB-76 AM radio broadcast. I’d like to make it sound like the station is being hijacked.
As an example, here’s the UVB-76 livestream: https://youtu.be/fUgzv-8_EMc
This code, when run in the Nyquist Prompt effect (https://manual.audacityteam.org/man/nyquist_prompt.html) will generate a similar buzz to your example:
;type generate
(setf base 217)       ; base frequency (Hz)
(setf dur 1.2)        ; buzz duration (seconds)
(setf level 0.8)      ; peak level (linear)
(setf filterhz 2000)  ; low pass frequency (Hz)
(defun mkwave(base)
  (setf wave (build-harmonic 1 base))
  (setf nyqhz (/ *sound-srate* 2.0))
  (do* ((i 2 (+ 1 i))
        (hz (* i base) (* i base)))
       ((>= hz nyqhz))
    (setf wave (sum wave (build-harmonic i hz))))
  (list wave (hz-to-step 1.0) t))
(setf *mytable* (mkwave base))
(let ((env (stretch dur (pwl 0.014 1 0.1 0.5 0.95 0.5 1))))
  (setf buzz (osc (hz-to-step base) 1.2 *mytable*))
  (setf buzz (mult env buzz))
  (setf buzz (lowpass8 (lowpass2 buzz  (* 1.5 base)) filterhz))
  (setf peak (peak (s-abs buzz) ny:all))
  (mult (/ level peak) buzz))
The buzz can then be mixed with some noise and repeated (https://manual.audacityteam.org/man/repeat.html) multiple times to give a result like this:
If you want retro soviet sound, there’s an app for that …
https://www.audiothing.net/effects/wires/ (64-bit only, PC & Mac)
The free demo version of the plugin has ~2 seconds of spoiler-silence every ~40 seconds,
that’s more than sufficient for a lo-fi intro.
