How to make a witch voice
Hii im brand new to this kind of stuff abd i have a question.
I tried to record my own voice for an edit and i want to make ny voice into a witch voice but i don‘t know how to do it can anybody give mi a tutorial how do do it?
Thanks for help
speech-to-speech AI, e.g. … https://elevenlabs.io/voice-library/witch
I see you want to do this in post production, but if you ever want to do that live, an I9 voice changer can be placed between the microphone and the recording device. They are not very expensive. The cheaper ones don’t have audio input and output connections, just a built-in microphone and speaker.
This is what ChatGPT ‘thinks’:
Example settings in Audacity
If you want a classic “evil witch” voice:
  • Pitch: −3 semitones
  • Bass & Treble: +3 dB bass
  • Compressor: light compression
  • Reverb:
    • Room Size: 20%
    • Reverb Time: 1.5 s
    • Wet Gain: −15 dB
  • Distortion: Soft Clip with a low drive
For a supernatural witch
Try duplicating the track:
  • Track 1: original.
  • Track 2: pitch −12 semitones, volume about −20 dB.
  • Track 3: whisper the same lines, add lots of reverb, volume −12 dB.
This creates an eerie “multiple voices speaking at once” effect.
