How to link audacity with audio.com
I signed up for audio.com. The final step is a button to link with audacity. The button doesn’t respond. I need to send a file this Monday. What can I do? Thanks.
My advice would be: “Don’t bother”. It is safer to back up to a physical device such as a USB memory stick than backing up to “the cloud”.
Steve, it’s not a question of storing. The file is in audacity. I need to send the file to someone. If not through audio.com, how can I do that? Thanks
Google Drive, One Drive, iCloud, Dropbox, …
For smaller projects, good old email may be sufficient.
The button issue might be a bug—try updating Audacity, clearing cache, or using another browser. If it still doesn’t work, export your file directly from Audacity and upload it manually. For guidance, check a step-by-step LetsBuildUp blogging tutorial style—same method applies: break down the process into clear steps to reach your goal smoothly.
Thanks so much, Andrew.
Looks like Andrew asked ChatGPT.
