How to Isolate Droning Sound
I have an audio file that I’ve recorded from my phone. I’ve made it mono and I’ve increased the amplification but there’s static on the entire recording that I’d like to remove and then there’s lower frequency noise that I’d also like to remove.
I’m trying to isolate a motor noise that’s oscillating or droning like sound and it’s difficult to hear in the recording.
I’m not sure if it’s the best way to go because there’s higher audio levels through the entire clip but I tried copying the track and using a high pass filter to Isolate most of the the static and then used that as the Noise Profile.
That seems to help a little but then I can’t get rid of the other lower frequency noise to isolate the droning sound.
Notch filter, or spectral editing.
