How to install VST plug-ins? [SOLVED]
I want to install GSnap plug-in. I pasted GSnap.so file to /usr/bin/plug-ins, then I pressed Edit → Preferences… → Effects, but I didn’t find “VST Effects” groupbox.
Audacity 2.0.5
The plug-in: http://www.gvst.co.uk/portpage.htm
Audacity 2.0.5 is obsolete now and does not support VST plugins on Linux.
If you need a Manual for that 2.0.5 version, please download https://storage.googleapis.com/google-code-archive-downloads/v2/code.google.com/audacity/audacity-manual-2.0.5.zip, then extract the “help” folder to /usr/share/audacity.
For VST support in Audacity, I suggest you uninstall the Mint-packaged version of Audacity 2.0.5 then install the Ubuntu Handbook 2.1.2 PPA version of Audacity from https://launchpad.net/~ubuntuhandbook1/+archive/ubuntu/audacity. Install the PPA version that corresponds to the version of Ubuntu that your version of Mint is based on - see https://en.wikipedia.org/wiki/List_of_Linux_Mint_releases.
If the 2.1.2 PPA lacks a Manual, you can obtain it from https://www.fosshub.com/Audacity.html/audacity-manual-2.1.2.zip.
For VST support in Audacity, I suggest you uninstall the Mint-packaged version of Audacity 2.0.5 then install the Ubuntu Handbook 2.1.2 PPA version of Audacity from > https://launchpad.net/~ubuntuhandbook1/+archive/ubuntu/audacity> .
Thank you! I installed Audacity 2.1.2, then I pressed Effect → Add / Remove plug-ins … and enabled GSnap. It works.
Are there any translations of manuals?
I am afraid not.
I will mark this topic [SOLVED] and lock it, given you seem satisfied.
