How to insert silence into audio gaps
Hi guys, I’m so close to automatic a process that normally takes me hours, but I’m missing a step.
If I record a single track of multiple audio clips, say the alphabet, how do I automatically insert silence into all the gaps to make the Detach at Silence feature work for me?
Normally I need to go in, select each audio clip, and upload it individually. But if I can somehow turn those gaps into silence, I can upload multiple clips at once!
Thanks!
Use this Noise Gate plug-in: https://wiki.audacityteam.org/wiki/Nyquist_Effect_Plug-ins#Noise_Gate
“Level reduction:” needs to be set to -100 to give total silence.
Installation instruction for Nyquist plug-ins on macOS: https://manual.audacityteam.org/man/installing_effect_generator_and_analyzer_plug_ins_on_mac_os_x.html#nyquist_install
The next Audacity release will include a version of this plug-in.
WOW. Thank you. Like MAGIC!!!
