I recorded a cassette and the beginning portion of the track is low and muffled. I’ve tried the recommendations for amplify and the envelope, but neither worked. . Any ideas?
I’m new to the program so I have limited knowledge.
Thank you in advance!
Try* boost treble … https://manual.audacityteam.org/man/bass_and_treble.html
(* if there is no treble to boost, then that won’t help).
If the section sounds muffled, you probably have too much 400Hz bandwidth. Try the following…
Thank you so much!
