How to import .wav file using mod-script-pipe
Hi,
Today (not without adventures :wink:), I managed to build Audacity 2.3.3 with mod-script-pipe.
But I cannot find a way to import .wav file into audacity via script.
Examples like this (which among other things import wav file):
are no longer up-to-date I’m afraid.
Command Import Audio unfortunately has no parameter available and opens dialog window.
Manual (Scripting Reference - Audacity Manual) says that:
Actions that end with ā€˜ā€¦ā€™ and have ā€œParameters noneā€ listed will pop up a dialog during the script to get the paramters, and are not properly supported by scripting. Use at your own risk.
Do you know of some workaround? I have like 2k small files and want to batch process them using some of the effects (e.g. PaulStretching).
Does the scripting command ā€œImportā€ (ā€œImport2ā€) from the ā€œExtra menu > Scriptables IIā€ work for you?
Note that you have to use a fully qualified file name, for example, to import a file ā€œfile-name.wavā€ from the Desktop of a user ā€œuser-nameā€:
/home/user-name/Desktop/file-name.wav
Thanks Steve, it worked!
I thought maybe someone will need some updated example on how to batch process many files so I will paste it here (much of the code is copied from: https://github.com/audacity/audacity/blob/master/scripts/piped-work/recording_test.py):
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import errno
import fnmatch
import os
import sys
import tempfile
# INITIALIZE READ AND WRITE PIPES
if sys.platform == 'win32':
    print("Load and save wave test, running on windows")
    toname = '\\\\.\\pipe\\ToSrvPipe'
    fromname = '\\\\.\\pipe\\FromSrvPipe'
    EOL = '\r\n\0'
else:
    print("Load and save wave test, running on linux or mac")
    toname = '/tmp/audacity_script_pipe.to.' + str(os.getuid())
    fromname = '/tmp/audacity_script_pipe.from.' + str(os.getuid())
    EOL = '\n'
print("Write to  \"" + toname + "\"")
if not os.path.exists(toname):
    print(" ..does not exist.  Ensure Audacity is running with mod-script-pipe.")
    sys.exit()
print("Read from \"" + fromname + "\"")
if not os.path.exists(fromname):
    sys.exit()
print("-- Both pipes exist.  Good.")
tofile = open(toname, 'w')
print("-- File to write to has been opened")
fromfile = open(fromname, 'rt')
print("-- File to read from has now been opened too\r\n")
def send_command(command):
    print( "Send: >>> "+command)
    tofile.write(command + EOL)
    tofile.flush()
def get_response():
    result = ''
    line = ''
    while line != '\n' :
        result += line
        line = fromfile.readline()
    return result
def do_command(command):
    response = get_response()
    print("Rcvd: <<< " + response )
    return response
def import_wave(input_path):
    do_command("Select: Track=0")
    do_command("Import2: Filename={}".format(input_path))
def export_wave(output_path):
    export_command = "Export2: Filename={}".format(output_path)
    do_command(export_command)
def remove_selected_track():
    do_command("RemoveTracks")
def paul_stretch_track(stretch_factor, time_resolution):
    do_command("Paulstretch: Stretch Factor={0} Time Resolution={1}".format(stretch_factor, time_resolution))
def change_tempo(percentage, sbsms=False):
    do_command("ChangeTempo: Percentage={0} SBSMS={1}".format(percentage, sbsms))
def get_files(path, get_absolute=True, extension='wav'):
    path = path.replace('\\', '/')
    matches = []
    for root, dirnames, filenames in os.walk(path):
        for filename in fnmatch.filter(filenames, '*.' + extension):
            if get_absolute:
                filepath = os.path.join(root, filename)
            else:
                filepath = os.path.join(root[len(path) + 1:], filename)
            matches.append(filepath.replace('\\', '/'))
    return matches
def make_sure_dir_exists(directory, is_file_path=False):
    Forces creating directory if such does not exist.
    :param directory: path to directory that we wish to exist
    :type directory: basestring
    if is_file_path:
        directory = os.path.dirname(directory)
    try:
        os.makedirs(directory)
    except OSError as e:
        if e.errno != errno.EEXIST:
            raise
if __name__ == '__main__':
    folder_with_waves = '/home/dankal/bazy/test_base'
    output_folder = '/home/dankal/bazy/test_base_stretched_output'
    for relative_path in get_files(folder_with_waves, get_absolute=False):
        input_path = os.path.join(folder_with_waves, relative_path)
        output_path = os.path.join(output_folder, relative_path)
        make_sure_dir_exists(output_path, is_file_path=True)
        paul_stretch_track(20, 0.5)
PS.I had some problem with missing ChangeTempo effect, but I decided that I’ll use soundstretch directly, in command line (I assume you still use it, just for some reason it did not get installed).
Thank you for sharing your Script.
I would suggest that an easier approach might be:
import pipeclient
https://github.com/audacity/audacity/blob/master/scripts/piped-work/pipeclient.py
