I purchased RX10 Elements in February 2023 thinking it was stand alone. Later I learned that it is “plug in” only and it is too late to request a refund. Has anyone found a work around to get Audacity to work with RX 10 elements? The RX 10 repair assistant will launch but it cannot “Listen” to the audio. The Audacity Audio will not play while the RX10 module is open. Also, I cannot find a way to play the audio in real time while I am tweaking the RX 10 controls.
Your advice would be appreciated.
Kind regards
Chris
