I have an audio track in stereo, with clear left and right channels. I want to split these into 2 separate tracks and export them in 2 files without them interfering one another. How ? Thanks.
There should be more than one way to do it, but this will work:
Split Stereo Track allows you to edit the left & right separately.
After splitting, click the little “X” to the left of one waveform to kill it.
Export the remaining track as a mono file. (In case you don’t know this, a true-mono file will play through both speakers.)
Edit → Undo, to restore the deleted channel, and repeat keeping/exportin the other channel.
Thank you.
