Chris designed a compressor so he could listen to Opera in the car. As a side benefit, it makes the performance louder and evens out the loudness variations. Use it out of the box. If you need the performance tighter, change the first number, Compression Ratio to a higher number. I use 0.77 to simulate the local radio station.
