How to do L-R channels in Audacity?
Audacity is my exclusive audio editor since long time ago.
Can someone show me how to do L-R channels please?
Thanks in advance!
Could you be more specific? What are you trying to do?
Oh, sorry!
for example I have one stereo music
What to do the Left channel minus the Right channel?
In Audacity 3:
  • click on the Audio track drop-down menu and select “Split Stereo to Mono”
  • select the lower track by clicking in the Track Control Panel area
  • from the Effect menu, choose “Special > Invert”
  • from the Select menu, choose “All”
  • from the Track menu, choose “Mix > Mix and render”
The result is one mono track that is the difference between the left and right channels.
The resul is one kind of ‘oops’ and encrease the level of the music.
Tests :
the level of the stereo source need encrease in 0,613 to have 0 dB
The job of L-R need to encrease -0,111 to have 0 dB
The job of R-L need to decrease -3,771 to have o dB
Thank you for fast answer and good will , billw58! :smiley:
billw58
as i don’t know how to edit the posts here i had to do this new
don’t use “Mix > Mix and render”
After invert the channel, use “Join Stereo Tracks”
and after that use
“mix Stereo to Mono”, this will give result without clip the audio.
You can do L-R in this way and R-L in the same way!
Join the resulti in a new steroe track but you’ll have the same audio
where one channel is inverted with the other.
Cheers!
Or, insert in my steps, set the volume of each mono track to -6 dB before mixing.
Yes, set the volume of each mono track to -6 dB before mixing is a good way too,
Thank you for this new hint! :+1:
