We would like to update our Audacity installations to the newest version 3.1.3 but we noticed that “Check for updates” is enabled by default. How can we disable this by default for all users? We use silent insall (audacity-win-3.1.3-32bit.exe /VERYSILENT /NORESTART) in our batch scripts.
Are you just wanting to set the default value, or do you want to permanently block Audacity’s update checking even if the user tries to enable it?
If it’s the former, you only need to set the value once when Audacity is installed.
If the latter, then use your firewall, or whatever method you use for other apps, or simply deny Internet access to those computers.
Out of interest, why do you want your users to use obsolete versions of Audacity? Isn’t it normally considered good practice to keep your software up to date?
If Users<username>\AppData\Roaming\audacity\audacity.cfg exists when Audacity is launched, then Audacity will use it.
If Users<username>\AppData\Roaming\audacity\audacity.cfg does not exist when Audacity is launched, then Audacity creates a new (initially empty) “audacity.cfg” file, and then populates it with default settings.
When the user changes a Preference setting, the audacity.cfg file is updated.
So by creating a Users<username>\AppData\Roaming\audacity\audacity.cfg file with your installation script, you can set whatever default Preferences that you want.
Really
I’m a Linux guy, and on Linux it’s a standard option to create a home folder when adding a new user. If that’s not possible on Windows then I’d be shocked. Try asking your SysAdmin how to do it.
So I don’t know if this helps, but for the current user, and depending on the program you are using, %appdata%\audacity is equivalent to Users<username>\AppData\Roaming\audacity.
